주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude E5400 노트북 컴퓨터는 Intel Core 2 Duo T7250 / 2.0 GHz 프로세서를 탑재하고 있으며, 1280 x 800 (WXGA) 최대 해상도를 지원하는 14.1인치 화면을 갖추고 있습니다.
Why is windows 7 always crashing
So i have this dell latitude E5400 so its windows 7 ultimate we bought it at 2012 for me by my dad i know its old but it works perfectly si my dad bought disks for installation of windows 7 rog (custon made OS) it works perfectly then i installed minecraft at it it works fine but moving is a bit laggy tho i got a little carried away by playing the laptop itself overheated then the next day it works still fine but because of school i have to upgrade it to windows 10 because of alot of homeworks i didnt have time to use it then one year later (its 2020) i turned on my laptop and booted windows 10 then i played minecraft about 2 hours later my laptop suddenly shut down and restarted then i got a warning thing i guess it says “no bootable device detected please reseat hard drive”. Then i did what is says soo i opened the cover and put it out and put it back again after that it booted fine and another 2hrs it happened again.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @justalvin
I would suggest you to do diagnostic test.
I think this model dell has a diagnostic test inbuilt
When you power on the computer press F12… check for any diagnostic options…
or perhaps ….
Press D  + Power Button For Diagnostic
Press FN + Power On
check especially on the hard disk
if hdd is having issues, suggest you to get SSD for a long term replacement and excellent performance.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
OP needs a SATA II compatible SSD for this - the Fixed III drives don't work in this as it's a SATA II system. Should also support SATA I just in case.
댓글 달기
답변을 추가하세요
Alvin Gabriel Mendizabal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 360
