주요 콘텐츠로 건너뛰기
Announced in August 2017년 8월에 발표된 Galaxy Note8을 회수된 Galaxy Note7의 후속 모델입니다. Note8은 대중이 구매할 수 있도록 2017년 9월에 공개되었습니다.
Unsure about screen protector type?
I bought a preowned phone from boost mobile. Phone was absolutely great from the moment t I got it. Heck it even came with a screen protector already on it. So like any responsible owner I went and bought a case, and that's when it all went wrong. After a few days I started to notice the edges of where the screen and the case meet started to peel up. I take the case off and apply pressure to these areas and it would mostly “lay" back down. Case goes back on and then it got worse. So last night having got tired of looking at it, I attempted to remove it….. this is where I went wrong. Only the areas that were peeling broke off. I know it's some kind of glass because it cut me. I have no idea what kind of screen protector this is and now I have its glass sticking up and it won't come off! Someone please help me and tell me what to do…..thank you in advance
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
@dreemsofsleep here are some guides:
https://www.wikihow.com/Remove-Tempered-...
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I actually tried that before I posted the question any other thoughts
honestly..that should do it....if you really wanna go for broke: remove battery...place glass side down in flat container with 99% alcohol to let it soak under the glass protector. i wouldnt do this though, the other methods should be more than capable of removing....perhaps consider taking it to a shop
댓글 달기
Easiest way (from experience) to remove a glass screen protector is to work a credit card between the phone and glass then slowly and gently work it further under untill it pops off, I have been able to get them off in one piece in the past using this method.
Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I tried that. It really seems like the protector is almost glued on
댓글 달기
답변을 추가하세요
Jeremiah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 63
