주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
McCulloch MC1275는 일반적인 물을 93도 이상의 온도로 가열하여 다양한 표면을 청소하고 살균하는 강력한 캐니스터형 스팀 청소기입니다.
Steam machine won't heat up.
When I turn on the unit, the light goes on but I don’t get any steam. I thought I put to much water in it. So I emptied unit started over, and still no steam. Is it possible the heating unit burnt out and is it something I can replace?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Same problem
의
water heats up ,but, no pressure or steam comes out.it work just minutes before..pouredcontents out ,red rubber substance came out.tried to clean as per instructions. [nothing changed] was this red object a washer or something else ?????
의
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Do both the Power On/Off light and the Steam Ready light come on when you switch the cleaner on? Not quite sure if this is what you meant when you said”… the light goes on….”
If the Steam Ready light doesn’t come on it may be a heater problem or perhaps a thermostat problem
If they both do come on try clearing the machine of any buildup of mineral deposits to see if this resolves the problem
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Still not working
의
For future ref: there's a thermoresistor thats placed on the side. If that goes out, u can try & find a replacement or at ur own risk leave it out. Caution, if u don't know about thermo resistors than u r not experienced enough to do this procedure. I took out all cut-out power items with the lines running direct to heating elements. This is not adviseable only to responsible enough not to leave machine unattended while plugged in use. But the machine still works. You got to be aware of the machine blowing the hose if your not aware the signs this machine works. And plugging & unplugging after every blast.
의
댓글 달기
답변을 추가하세요
baschilz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 10
지난 30일: 23
전체 시간: 4,125
