주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MacBook, MacBook Pro 및 MacBook Air에 사용되는 AC 전원 어댑터. 잡아당길 때 안전하게 분리되는 자가-정렬 자성 커넥터를 사용합니다. 1 세대 (2006-2012) MagSafe 충전기는 약간 두꺼운 L 자형 커넥터가 있습니다. 45 W, 60 W 및 85 W 버전으로 제공됩니다.
Can the box be repaired?
I charge from a generator occasionally. There has been a trend of things pugged into the generator dying. I think by turning off the generator while the charger was plugged in, it may have dropped voltage under the acceptable range. What would this do to the box to make it not work, and how can it be fixed?
I’m on my way to best buy, where I’ll pick up a new one because I can’t work without the charger, but I’ll return that if I can get this one running again.
Any help would be wonderful.
Be healthy!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Generators can create surges which can damage chargers, power supplies and systems. I would strongly recommend getting a good surge suppressor for your system and its peripherals. Did you look at getting a UPS? Or an anti-vampire outlet strip? COMPLETE GUIDE TO VAMPIRE POWER
You selected a MagSafe charger what system are you using? Did you check the systems battery? Install this gem of an app CoconutBattery. Take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
john o'bryan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 24
전체 시간: 276
