주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
32GB 또는 128GB 저장 용량으로 제공되는 5세대 Apple iPad(4G LTE 지원)에 대한 수리 안내서, 분해 정보 및 문제해결 정보입니다. 2017년 3월에 출시되었습니다. 모델 번호 A1823으로 식별할 수 있습니다. 9.7인치 Retina 디스플레이와 64비트 A9 프로세서를 탑재하고 있습니다.
iPad 5 Not Charging
I had a customer bring me an iPad 5 that doesn’t charge. I managed to get it to charge at 1amp sometimes but most times it charges at 0amps…
I checked vchargr and it was showing 4.2volts.. I changed Tristar and now the line shows 5 volt and I also changed charge flex and that didn’t do anything either…. So I tested vbatt on battery connector while plugged in and it shows 1.4 volts instead of 3.7 volts. I looked at a schematic board view for an iPad Air and they are totally different…
I plugged cable in without battery and the amperage goes to about 0.12 amps 0.15amps 0 then moves around but when I plugged battery back in and it boots, it goes back to 0 amps…
Did I install Tristar wrong or is something on vbatt line bringing the voltage down.. When the iPad boots, an I have cable plugged in, it says unlock device to use accessory then starts charging at 0.5amps which should be 2 amps…
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
This is me the author from above.
i am just letting everyone know that I replaced tristar again with a new one and the iPad charges again!
just thought I’d let everyone know in case someone has the same issue as me. Make sure tristar is working !
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Daniel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 511
