주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2011년에 출시된 Asus K53SV는 2세대 Intel 프로세서와 전용 Nvidia 그래픽 카드를 탑재한 15.6형 노트북입니다.
touch pad replacement Asus n53
My top cover broke and I got a replacement for it but comes with no touchpad. is it possible to remove the touchpad from the original cover and install on the new cover? if so how can I do it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
Can you add pictures of the new cover and the old one, it would help to know more exactly what part is missing on the new one and needs to be moved.
기존 질문에 이미지 추가하기
의
Apologies. Unfortunately I've already fixed the device therefore I won't be able to take any pictures.
The touchpad board is actually glued to the cover I had to heat up the touchpad area on the cover (not the board) and used a metal pry tool from my IFIXIT to remove it.
Bit by bit the glue was coming off.
I was able to just stick it to the new cover and is working well
의
댓글 달기
답변 1개
Hi @xinwarrior
Based on some research into the ASUS N53 it looks like this touchpad is easily transferred after removing a few surrounding screws.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joao Araujo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 20
전체 시간: 629
