주요 콘텐츠로 건너뛰기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
175 질문 전체 보기
Do I need a new mainboard?
Some liquid spilled in onto the switch, which afterwards someone tried to turn on.
Ive taken it apart a bit to clean residual liquid, but it seems like some components are fried.
Its located under/near the left speaker housing, and where it says Side-B UM.
I assume I'll need an entirely new mainboard?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
zachary ortmann … your board can be salvaged. clean the pcb with some 99% isoproply and a soft bristled brush and make sure that all corrosion is taken care of. next, youll need to troubleshoot which components are shorted by taking reading with a multimeter. replace those that need replacing. keep this up until the issue is resolved. without a schematic it will be hard unless its obvious. replace the obvoious and hope it powers on. if not, youll need to google the board schematic and hope you find something to verify measurements against. if youre not able to find anything, a tech should be able to salvage. depending on what they will charge will be what determines if you should just buy another board. good luck. if you find schematics and have questions, post back with a link and pics and we can help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zachary Ortmann 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 113
