주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 노트북은 2000년 2월에 출시되었고 2001년 1월에 단종되었습니다. 모델 번호는 M7572입니다.
System will not startup - Dead Battery?
Aloha All,
My friend has a Apple PowerBook G3 400. The powerbook laptop battery is dead and will not charge. I have removed the battery and just plugged in the AC Adapter. The system will still not start up. Could it be that I will need to get a replacement battery to get the system to boot?
Thanks,
supertechhawaii
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Before you worry about the battery pull the PRAM battery--its easy just open the keyboard. I'll include a link for you. In these models a bad PRAM battery will keep the computer from booting and you can run it without the battery. You do not need to disconnect the keyboard to disconnect the battery.
Good luck.
PowerBook G3 Pismo PRAM 배터리 교체
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Aloha rj713,
Thanks for the help and the link :) Is the PRAM chip a standard 3V button battery?
Thanks,
supertechhawaii
의
Unfortunately its not. It's a fairly expensive battery and if connected to the web not really needed. Just select time in system preferences and select automatic update. Otherwise you will need to set time and date when you boot the computer.. Link to used battery included.
http://www.ebay.com/itm/PowerBook-G3-Pis...
의
댓글 달기
답변을 추가하세요
supertechhawaii 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 33
전체 시간: 1,673
