주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
320 Gb HDD from Toshiba
iPod Classic (new one) will accept Toshiba 320 Gb HDD?
What about this: http://www.amazon.com/Apple-iPod-classic...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 5개
need more information on the 320GB. What is the drive number? What is the interface....your ipod is a 6th gen classic?
If your question is if this one will accept the above drive, then the answer is no. Same problem.
Thank you verry much.
You are welcome, good Luck
댓글 달기
답변 2개
선택된 답변
If you are thinking about using the Toshiba MK3233GSG in your ipod, then the answer is no. It will not work because it has SATA interface. The 320GB is a dual-platter one, that means that the interface wont fit and it has different mechanics as well . The HDD for the 160GB iPod is 5mm thick and the 320 GB is 8mm. Hope this makes sense. Good Luck
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
There is a 250GB drive out there with an ZIF - IDE Interface. As far as i remember they tested it in a 5.5G iPod Video and it worked.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks you :)
댓글 달기
귀하의 답변을 추가하세요
Ted 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,359
