주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
will not power on
after replacing my screen and digitalizer my ipod will not turn on. when remoivng the screen on the top left corner an orange ribbon was cuz by glass just after the screw where its held in place. is this the reason as to why it will not power on??
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 3개
michael, go this guide iPod Touch 4th Generation Front Panel Replacement and see if you can somewhere identify the cable in question. Are you saying it got cut when you removed the screen?
on step 12 u can see it next to the grounding wire its the orange ribbon. yes the glass was shattered in that corner n when removing the screen it was cut by the glass
you are correct apperantly it wasnt snapped together securely and now will power on tht the battery has died. but if it is my wifi cable that was cut how can i replace it?
댓글 달기
답변 1개
선택된 해법
That looks like your Wifi cable...recheck all of your connections and make sure (triple check) they are all seated properly. Also charge your iPod on an AC wall charger and see what happens. Yes, you can replace the cable. It is available at places like this. Good Luck to you and your iPod.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
michael 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 782
