주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
최신 Nespresso Vertuo 싱글 서브 커피 머신: 대담한 디자인과 향상된 유연성 및 편의성을 갖췄습니다. 버튼 하나만 누르면 알토(Alto), 커피, 에스프레소를 따뜻하게 또는 차갑게 추출할 수 있으며, 자연스러운 크레마가 형성됩니다.
Can someone provide a dissembling tutorial for this machine?
I would greatly appreciate if someone provided a tear down video for this machine. My gf’s machine is experiencing a coffee leak. The coffee leak may be cause because of some piping issue, may be clogged with ground coffee bits, not entirely sure. It is also causing an inconsistent coffee flow, this machine would normally pour of coffee in a smooth stream but now seems to be intermittent. Also, because of the clogged pipes and unnatural coffee flow it seems to have built up coffee in the canal area where you load in your pods, which causes the machine to leak coffee.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 4개
I have one of these partially dismantled but only the outer cases, water supply piping and base so far.
The real problem is the electronic/mechanical drive system for the top!! Pure lazyness really, what's up with just clipping it down by hand!,
So, I am reluctant to press on and break some crucial part.
If someone at iFixit wants me to send them the rest of this machine to use as a guinea pig let me know :)
J
@jpirie Any luck opening the pod bay?
Hi Nathen,
Not as yet. I admit to not having tried too hard though...It's not my coffee machine and has been donated as a project. As such it has been lying under the bench partially dismantled for a wee while :)
I will get round to trying though but...even if I do get it apart..I'm totally unsure of where the coffee is leaking from and how to stop that :( I usually have at least a half clue as to what I am trying to achieve .
Such a stupid design really.
I have drown into internet seeking a diagram and I have no lucky at all! someone will have the diagram of this coffe maker? Nesspreso VertuoPlus GCB2 pliiiiiiis!
댓글 달기
답변 1개
선택된 해법
Hi Peter, watch this youtube video https://youtu.be/b86_d7i0Eug to take the sides off a Nespresso VertuPlus. This same author has video that shows how to remove the bottom too. I have yet to find a schematic as well. Hope this Helps - KC
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Peter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 71
전체 시간: 9,023
