Tip snapped off inside.
I purchased a used apple pencil 2nd gen. and the tip is snapped off inside. The end part of the tip that’s a hollow circle. Any ides on how to get it out? I’ve been trying tweezers with no luck.
좋은 질문입니까?
좋은 질문입니까?
I have used a needle and rotate ccw, push pin or something might work too
이 답변이 도움이 되었나요?
I managed todo this with a sim ejection tool. I just keep turning until it was a little higher and was able to tip it out and put on a new end
Hi
Sorry to hear about your Apple Pencil
Let’s get it doing what it does best!
My advice here would be to get a sewing needle and scratch a small divot into the bit stuck inside until you have enough leverage to start Turing it out!
If that doesn’t work try using a small flat head screwdriver carefully as this method is to be used as a last resort.
If you need any help with it please do not hesitate to ask
Hopefully all goes well for you
이 답변이 도움이 되었나요?
Hi, my pencil connects to the iPad when it is placed next to it, but when I want to work with it, it does not work at all and the tip of the pen does not communicate with the surface of the iPad.
이 답변이 도움이 되었나요?
Hi, I have more or less the same issue… Any news on how to fix this?
Greetings!
My pencil snapped inside as well, is there a way to get it fixed ? Or getting a new one is the only option?
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 13
지난 30일: 33
전체 시간: 5,401
댓글 1개
Can you post a few pics that clearly show things 기존 질문에 이미지 추가하기
DanJ 의
