주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월에 출시된 모델 번호 ME-9Q로 식별되는 쿼드 코어 9인치 Android 태블릿
Why does my unit will not boot. E: Check failed
I took the SD card out and reformatted for three different formats. that still didn’t work I tried clearing out memory an whole a bunch of stuff in the boot screen. With no luck.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Try booting your device into “Safe Mode” and performing a factory reset. Keep in mind that this will erase all your saved files (so back them up to a removable storage device), but it may also fix the problem.
  1. Turn on the tablet.
  2. Press and hold down the Power button until the Power Menu appears. This menu should have an option to Restart the tablet.
  3. Press and hold down the Restart option until a message appears asking if you would like to boot into Safe Mode. Select OK.
  4. When the table boots into Safe Mode, go into the Settings app and look for the Factory Reset option. This will erase all the data on your tablet and reinstall the operating system, giving you a fresh start.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Tried that was no safe mode but did the complete reset. Still no luck. Are you talking about a Visual Land Prestige Elite? 10Q Did a Hard Reset says wiping complete then reboot again does not show any problems. But when I do a recovey system from backup. I get a E : Check failed.
의
댓글 달기
답변을 추가하세요
doug 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 422
