주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
서멀 사이클러에 대한 수리, 지원 및 서비스 정보입니다. PCR 장비 또는 DNA 증폭기로도 불립니다.
Support of Bio-Rad S1000 PCR
The S/n under 10,000 is no longer supported can you guys work on these?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
I have a problem, I was using two PCR (C1000 Touch thermal cycler) at the same time because I'm having many samples, unfortunately, all of them stopped working, and when I switch them on it only ended with SYSTEM INITIALIZATION on the screen.
Can anyone help me how to fix this problem?
Gregory
댓글 달기
답변 1개
Hi Chad,
I had at least couple of these with 1 (that is ONE) faulty capacitor in power supply that manufacturer solution was not to repair but to supply whole board. If your PCR machine doesn’t power on or shuts off occasionally, could be that capacitor C19 100uF has to be replaced. Hopefully you can find someone to do that for you. Make sure that backup battery on the board is NEVER REMOVED!!! because you will loose firmware data and machine will become unusable. If you have problem with the block then i’m afraid there wont be much you can do.
All the best
John
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
how to connect s1000 bio rad thermal cycler to computer?
댓글 달기
답변을 추가하세요
chad richardson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 28
전체 시간: 1,186
