주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Moto Z Play(모델 번호 XT1635-02, XT1635-01 및 XT1635-02)는 2016년 9월에 출시된 드로이드(droid) 스마트폰입니다. Moto Z Play는 기기 앞면 상단에 있는 “moto” 로고와 하단에 있는 사각형 홈 버튼으로 쉽게 구분할 수 있습니다.
How to remove stripped screws?
Hello, I am trying to replace a battery on the moto z play phone. I got the back off and screen separated. But can not get the little screw out to remove the metal piece holding the battery cord in place. Anyone have a suggestion on removing stripped screws? I have tried the rubberband trick but no luck.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Have you tried other screwdriver bits of different sizes and shapes? If that does not work you can carefully drill into the screw till the head comes off with a very tiny drill bit (see pin vise from here or amazon). Of course with this method you will have to replace the screw.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
That was not pretty. I ended up drilling the screws and doing my best to break off the top….which was challenging. I tried the rubberband trick and I think they were to far gone. The super glue did not hold and would just pop off. And then I even tried soldering the screw……nothing.
Anyway, I got the screw heads off and was able to move on.
Thank you for your responses and help. I greatly appreciate it. I am new to this….so lots of trial and error.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi Melissa,
A couple of options with stripped screws, drilling is an option as Josh mentioned, but first, to drop a little super glue into the screw, then pop the driver in, wait a few mins then twist out.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Melissa Odom 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 742
