주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA, 64 또는 256 GB 저장 용량 옵션을 제공하며, 색상은 금색, 은색 및 스페이스 그레이가 있습니다.
Touch Screen not working after replacement
Hi, so I replaced my screen and now the touch is not working really. If I disconnect the home button cable that is attached to the screen, the touch works, but I can’t get past the setup screen since I have to use the home button.
I am not sure why the touch works when only one of the screen cables is connected. Any help would be great!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
This is a common problem with the iPhone 8 series caused by the ground pins at the end of the home button connector being pushed in. If you have some sort of magnification you should be able to pry them out into their normal position.
이미지
Different screen manufacturers use a different Architecture. If those ground pins are pushed in it might only affect certain screens.
이 답변이 도움이 되었나요?
점수 3
댓글 4개:
Thank you! Is this the one on the motherboard or the cable in the screen?
의
It's on the motherboard
의
thank you alot..you are the man.. this solve my problem, I thought lots of things and was thinking the phone no longer working..
의
Thank you, but sometimes you may need to replace the entire connector.
의
댓글 달기
The top cable is for the earpiece speaker and proximity sensor. Middle connection is for the screen including touch. The bottom connector is for the home button. I would disconnect the battery and check the connections with a magnifying glass and see if you have any damaged pins. If they are fine I would clean the connectors with a qtip and alcohol and a soft brush, reconnect and check it.
Update (05/21/2020)
You could have damaged them while installing them. It's possible and the best way to find what is wrong is to make sure that everything else works until you get to the last possibility. And I have put on multiple screens on iPhone 8 plus and it has nothing to do with Apple. It's something that happened during the screen change or a defective part.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I can't see why there would be an issue with the pins since the old screen works just fine. I read something about Apple not enabling people to change screens on Iphone 8 + , but I am not sure if that is still true.
의
Do you think it's possible I need to try a different new screen and see if that one works?
의
댓글 달기
답변을 추가하세요
Zyzz Az 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 74
전체 시간: 4,296
