주요 콘텐츠로 건너뛰기
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
20 질문 전체 보기
Why cooling fan runs and engine won't start?
My car was running normally then switched off the engine for a few hours, came back and while trying to start again, cooling fan runs, no crank and engine won't start.
All dashboard lights on after single click on start button while pushing breaks (cooling fan runs), which is really weird coz engine is not hot. Another press on start button, everything goes off.
I recently changed radiator and spark plugs + 2 ignition coil.
Any idea what could be the reason and how i can fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개
We’re is the bcm I’m having the same Problem
And what all I have to tske off my part car with the same year 2007 to get this one running
Help....I am having this same issue. What did you do to fix it?
In my skoda fabia it was immobiliser. I just had to disconnect accu (battery) for 1 minute, then reconnect and engine started:)
I have the same problem but I have a '94 BMW 3 series
댓글 달기
답변 6개
선택된 해법
It may well be that the fault with the cooling fans has drained the battery too much, when it tries to start the battery voltage collapses and the electronics give up. Try charging the battery or use a booster pack to get it started, you can then drive it somewhere to get the cooling fan problem fixed - this may well need to be a main dealer with the right diagnostics equipment.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Try to change coolant temperature sensors.the sensor send wrong information to ecu.when ecu located engine temperature high,ecu send signal to cooling fan for running.and when engine hot it not start
댓글 달기
가장 유용한 답변
Mine did the same and it was the engine control fuse. It's in the fuse box under the
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Under the what? I cant see the rest of the text
Hood I think .
댓글 달기
This usually an indication you have a shot BCM.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Where ia this located?
BCM? What is that?
댓글 달기
I’m have this problem now . The guy look at it he put a used relay on my van and now the same thing is happening. I’m going to buy a new relay and get the battery charged and see what happens.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Did you find out what it was?
댓글 달기
It might be immobiliser. I disconnected battery for 1 min, reconnected it and the car started
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Anyone know why the headlights, blower motor and turn signals are all on at once without the car started?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
You might have a ghost in that cat!!!loli had battery and alternater checked out and they are good. Relay is what I’m thinking.
댓글 달기
답변을 추가하세요
Ahmad Nawar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 15
지난 7일: 121
지난 30일: 366
전체 시간: 25,547
