주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 10월 26일 출시. 모델 A1984, A2105, A2106, A2108. GSM 또는 CDMA / eSIM, nano-SIM 또는 듀얼 SIM / 64, 128, 256GB / 블랙, 화이트, 블루, 옐로, 코랄, 레드 색상으로 출시됨. ("아이폰 텐 R"로 발음함.)
Which microphone is broken?
Hi, My iPhone XR microphone doesn’t work on speaker calls but works fine on normal calls.
The strange thing is that Siri works fine, (which uses the earpiece mic),… and normal phone calls work fine which i believe uses the bottom mic.
Voice memos just records static, same as speaker calls for people on the other end listening.
Front facing and Rear facing video all record sound fine..What should i be replacing here?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 1개
선택된 해법
The connector microphones are located on the charging port assembly. One of these microphones has become faulty. I am not sure which one handles the voice memo and speaker phone. Replace the charging port assembly and the audio should be fine.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thanks for the quick reply Chris!, ill gave that a go and report back. I had no idea the bottom had multiple mics!
의
Hello please any update
I’m having the same issue
If you fixed the issue how did you do it?
의
댓글 달기
답변을 추가하세요
s_joseph_ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 28
전체 시간: 6,131
