주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ASUS Q536F는 2019년 5월에 출시되었습니다. 일상적인 용도와 게임 모두를 아우르는 경쟁력 있는 가격의 투인원(2-in-1) PC입니다.
Back Pannel Won't Come Off
There is something holding my pack pannel on and I can't figure out how to take it off. From the outside it looks like a circle made of the same material as the panel. I can pry it open and look inside and it seems to be a screw. I can't move it as there is nowhere to place the screwdriver. It may be on the otherside underneath a keycap but from what it looks like it doesn't like up with any keys. Pressing down on it does nothing, I can't rotate the back pannel off either. Anyone know what this is and how to get it off?
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 5개
Hi,
Did you look under the “feet” to see if there are any screws there, holding the cover on?
의
I can pry the whole thing off, its just that part in the middle that is holding onto it.
의
what screwdriver did you use to open the screws?
의
Maybe the screw is under the keyboard. Take out keyboard and have a look.
의
https://www.youtube.com/watch?v=WW30dcvq... this model should be the same frame. if it is holding in a obviously no bottom screw area you need to pop the plastic off from the top the keyboard and remove those screws to expose the screws that you need to get at
의
댓글 달기
답변 1개
선택된 해법
This is most likely a cover hiding a screw in the middle of a back panel. You can use a very small flathead screwdriver (e.g. flathead 1) to pry off the screw cover and get access to the screw head.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Braxton Biggers 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 25
전체 시간: 1,115
