주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2000-2006년형 BMW X5 모델은 BMW의 1세대(E53) 스포츠 크로스오버 시리즈입니다. X5는 2000년형 모델로 1999년에 처음 출시되었으며, 자동변속기 또는 수동변속기가 장착된 상시 사륜구동 방식을 채택했습니다.
Car stuck in limp mode..accelerator is not responding..changed accele.
Stuck in limp mode..accelerator does nothing..changed accelerator but same thing
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
You need to find the fault codes and that will give you a idea what you need to physically check. So this has a throttle sensor and you changed it and it didn't do anything. You need to test each sensor for input voltage and output voltage from the sensor to the ecm/pcm. You could have a mouse that chewed a wire. You need to find the flow chart for the trouble codes and follow them. Repairing automotive computer systems is not easy. It takes a lot of education and skill and thousands of dollars of equipment. My advice is if you aren't a trained automotive technician who specializes in diagnostic repair and has spent thousands of dollars on equipment, I would recommend taking it to a repair shop. You will probably pay more money throwing parts at it and not fixing it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
smokinsmitty.1972 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 11
전체 시간: 399
