이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
This question has a serious lack of information. How do you normally charge the device. I have a different smartwatch and I have to remove one part of the wristband and then plug the device into a charger. I did a little research on this and the consensus leads to the charger being the most likely issue. Contact Fitbit. https://help.fitbit.com/?l=en_US&cu=1&fs...
CASPER YOUNG 의
@manjunath.kalose.rao Check your charging port.
George Gibson 의
