주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
272 질문 전체 보기
Why is my phone not going past 69% while charging?
This week I could not get my phone past 69% of charging. I saw that it said that it would be 100% charge in about 39 min but a hour past and it did not pass 69%. Should I change the battery.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
this is another common issue. this is normal wear and tear over time, but can be exasperated by not using the proper charger and cord that comes with the phone. also, some batteries use a smart feature that learns charging behavior from the user. these are factors at play here with these types of issue.
solutions:
first you could try to re-calibrate the battery by completely draining it until it turns off (sometimes this is inhibited by a smart setting to turn off when low power is detected in settings) from there, youll want to let the phone charge to 100 percent before turning back on. see if this helps (not typical with todays li-ion batts)
if this fails, youll probably want a new battery. here is a link to replacing and to the part youll need. make sure to math the model number for correct specs:
Samsung Galaxy Note5 Battery Replacement
[[ 잘못된 부품 링크 ]]
if any further assistance is needed, post back here.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks a lot I let the battery to drain and it worked.
@totemicorc ... great news. good job.
댓글 달기
My phone has been on 69% for the past hr and I'm scared that its not gonna charge the whole night and I need my phone for school tomorrow what should I do?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
What happened. Did you mess up in class?
댓글 달기
귀하의 답변을 추가하세요
Eddie G 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 33
30일 전: 206
전체 시간: 7,664
