주요 콘텐츠로 건너뛰기
Device repair and information for the Soundsticks II speaker, designed by Harman Kardon in 2004.
22 질문 전체 보기
Harmon Kardon Soundsticks II Speaker Impedance
Need to ask if anybody knows the impedance rating of each of the eight (8) one (1) inch speakers on the Harmon Kardon Soundsticks II? Is it 4 Ohms or 8 Ohms? Looked every where without success and good grief even Harmon Kardon don’t even know!! If anybody also knows a good source to replace them please share that info.
Thank you
Update (07/17/2020)
All;
Found out the speakers are 8 Ohms impedance. Ordered 8 on eBay from a company in China and installed them within 60 minutes. Soundsticks II never sounded better. There are plastic 4 clips holding down each speaker and care must be taken. Best to use a small screwdriver to gently push one clip away from the speaker housing while pulling up and using a finger to push away the adjacent clip as well. Bonus: Each speaker removed has a very powerful permanent magnet that I now use as a fancy decoration piece.
Mac
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
I need to replace one of the speakers in one of my sticks. It's started to degrade. Do you mind sharing who you bought from off ebay? Thanks!
I have ordered replacement speaker from 3 different sources, all from China, and they all sound so tinny and lack any depth I find them unusable. What source did you use to get speakers that worked?
Hi there, I hope you see these comments asking which seller you found your speakers from, because I am another voice with the same question. Hope you get a notification from these. <3
댓글 달기
답변 2개
선택된 답변
Hi @maczones ,
Here’s a lot of info about a Soundsticks (not a Soundsticks II) that may help.
Scroll down to the bottom of the page and click on the Driver Speakers link.
In there it states (and shows in the images) that the speakers are 8 Ohm
There is a part # 300-0019-002 on the speaker but I got no results when searching using it, unless you can read German which I think leads here as a substitute but you better double check it
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
The link to the German speaker substitute is not good. These speakers will not fit well, as the housing assembly is not compatible. The other link you provided was very helpful to view the whole assembly and to view the speakers and find out the speaker impedance. The replacement speakers I found on eBay from a company in China have the perfect replacement part and that is the route anyone should consider taking to replace the speakers. Speakers cost about $8.99 for a pair, so for $36, you can rebuild the speakers and make your Soundsticks II, sound brand new again. Make sure when you order, you state you want 8 ohms impedance because the company in China also sells the same speaker assembly with 4 Ohms impedance.
Do you have the name of the company or any order info to order speakers from? I need to do the same thing.
댓글 달기
Die Anfrage ist zwar schon zwei Jahre alt, aber ich habe auch nach Ersatz für einen klirrenden Lautsprecher der Soundsticks gesucht und das gefunden: https://de.aliexpress.com/item/100500245...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Jan for the info and link. These speakers come in different sizes and electrical specifications, so good research is necessary to buy the correct replacement.
Danke Jan für die Info und den Link. Diese Lautsprecher sind in verschiedenen Größen und elektrischen Spezifikationen erhältlich, daher ist eine gründliche Recherche erforderlich, um den richtigen Ersatz zu kaufen.
댓글 달기
귀하의 답변을 추가하세요
Mac 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 31
전체 시간: 1,847
