주요 콘텐츠로 건너뛰기
조이콘 컨트롤러와 약간 더 작은 스크린이 통합된 보다 합리적인 가격의 순수 핸드헬드 버전의 Nintendo Switch의 게임 콘솔입니다. 2019년 9월 20일 출시.
175 질문 전체 보기
Adhesive foam for digitizer
I easily found a replacement digitizer for my scratched one on my Switch Lite (they’re all over ebay and Amazon), but it did not come with the adhesive foam to attach it to the LCD and the case. I can’t seem to find this foam anywhere, though I did see replacement foam for the regular Switch. Is this foam available somewhere or is there another solution for replacing the digitizer?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
I ended up using pieces from the Tesa 61395 card that iFixit sells. I did this for the outer ring of adhesive, the part that attaches the digitizer to the Switch itself. For the inner ring of adhesive, the part that attaches the digitizer to the LCD panel, I was actually able to carefully remove the old foam from my scratched digitizer and reuse it. It actually came off the old digitizer pretty easily when I carefully removed it with tweezers. I couldn’t salvage the outer ring in this way, though.
my inner foam tape is barelly sticky, is it supposed to be like that?
댓글 달기
답변 4개
Try some adhesive tape rather than the foam
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
did you ever find it? i need it aswell
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
sorry to revive an old question but did anyone ever find any of this foam? Or is Tesa Tape good enough? I’ve got a switch lite digi to replace but the owner already attempted it themselves and binned the old Digi along with the foam so I need to get replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The tesa tape works fine.
댓글 달기
Did anyone ever find the sizing you need? It comes in multiple mm thicknesses
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I think its 2mm
Thanks mate!
댓글 달기
귀하의 답변을 추가하세요
strells 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 12
전체 시간: 1,095
