주요 콘텐츠로 건너뛰기
Series of HP Pavilion laptops released in 2015. The 15-p is more difficult to service then later 15-x models.
(Black Screen of Death with Integrated Graphics disabled) PLEASE HELP
Hi,
I successfully Disabled [Intel HD Graphics] using device manager on my pc that has operates solely with a HDMI connected.
Disabling integrated graphics lead to no being able to boot into BIOS[iknow], Thus cannot boot into safe mode. Please help as this my only PC I have around
Things I have tried
  • -New HDMI and Monitor Connection
  • -Reseting the CMOS battery
  • -Boot into safe mode/bios
  • -Reseting/ Swap Ram slots
PC boot responses
  • -Light on power and LEDs
  • -Fan powered on
  • -USB and other ports working
  • -Beeping Noise when button presses with keyboard(USB)
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
The best way to deal with the BIOS video issue is just to pull the battery and start from ground zero - yes you may need to reconfigure some things, but it will get you into a better state then you are now at least on the firmware end instead of requiring you to tinker with it for hours. The problem is on the 15-p, the way you get to the battery is a proper nightmare since the motherboard needs to be pulled out. This guide is for the hard drive, but AT LEAST you’re halfway to the CMOS battery.
The second issue is if this is a SOFTWARE LEVEL device disable, you may need to reinstall Windows if you cannot get in through the normal boot process since you disabled the way in that always works. You may be able to get in through the normal boot process, but I would be ready to do an OS reinstall if you want to hope to get anywhere. To rule out if it’s the hardware once the BIOS works, boot it into Linux or a Windows install DVD - if it was successful, you’ll get an image on the laptop.
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
Thanks, I will look into that. Although I am not sure how to flash the PC with a black screen
@woof The battery removal will clear out any bad BIOS settings that caused it if it's due to a bad setting.
@nick Oh ok, would the bios boot onto a HDMI, since my OG laptop is display is removed/damaged
@woof It would help if the bad settings are the issue at the low level.
When turning on my laptop I have a black screen while the fan is working with loud noise sound, I have tried removing and placing my Ram on to another slot and it's the same ... I need help with the black screen.
댓글 달기
답변을 추가하세요
Bob Marly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 1,395
