주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
Check if SMC was reset
I want to do an SMC reset and did so by powering off, disconnecting cable, holding pwr button, plugging in, powering on. But is there a way to verify i reset the SMC successfully? Resetting PRAM/NVRAM is clear because you hear 2 chimes
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
I'm not sure I follow what you are looking for.
의
When you do the SMC reset, is there a way to know you did it properly? Like, sound cues, reset date/time or something like that. I want to know if i did it properly
의
댓글 달기
답변 1개
선택된 해법
A SMC reset null’s the values it holds so there is no means to tell for sure. What is the problem you think an SMC reset will alter?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It was high temps and weird fan controlling. But i think it did reset because the volume changed from max to 50%
의
댓글 달기
답변을 추가하세요
Max Tech 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 26
전체 시간: 528
