주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
Why is the screen flickering and also has faint white lines.
I installed the new ifixit iPhone 8 replacement screen onto the phone and when I started the phone up and got into the home screen, the screen was very low resolution, the screen was flickering and there were some white bars that were going vertically across the screen. Before I installed the screen I also noticed that on the screen flex cable connector there was a darker smaller pin that was different from the rest of them. I want to ask the community for some tips in fixing this problem before I have to return the product. Some help would be appreciated.
Thanks,
Dominik
Jurcins
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello Dominic,
Sometimes, there happens to be static involved when installing new screens. Take your phone apart, disconnect the battery, screen and install it back again. This usually fixes the static issue. As to your darker pin issue, it’s hard to tell if it would cause an issue without seeing a picture first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you for responding. I tried to do what you said but it is still doing.
댓글 달기
귀하의 답변을 추가하세요
Dominik Jurcins 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 58
