주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Huawei P20 Lite는 기술 대기업 Huawei의 보급형 스마트폰이지만 강력한 성능을 자랑합니다. 듀얼 후면 카메라와 놀라운 디스플레이를 갖추고 있습니다.
Display Brightness and screen bug
After changing display i got some issues. One of which is provlem with aux and thats why i had to open it again.After that opening i received ANOTHER glitch, which makes the phone to randomly change brightness to max while also showing black screen with the clock on the top right corner. Also when the phone is off it randomly turns off and shows the same black screen and logo. I will post picture of it.Help pls because after this i opened it again and coudnt find what is causing the problem.``
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Look like Smart Cover screen to me. You might want to disable it, unless you have phone in “smart cover” with a window.
https://consumer.huawei.com/en/support/c...
If the phone is switching off randomly, I would assume there is something wrong with the power button. Since you had the phone apart, it is quite possible that you have “messed up” something. So, have another look inside and focus on the power button and its connection to phone MB.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
KALOYAN 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 785
