주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
645 질문 전체 보기
water spillt! Starting problems. What should I do.
hello,
My macbook got water on it. I tried starting it once it was dry. It starts ans cut's off after 1 minute.
So I took it apart, but it seems like the motherboard never got water on it. All components seem clean and dry. I only had a issue with the keyboard staying blocked.
Once I put it all back together, I still had the same problem. Starting fine after 1 minute turning off.
I have a reset the SMC and PRAM. I have also done a apple hardware test. No results.
One more information, by deconnecting the track pad, the mac does not turn off.
What should I check, test? What is the next step?
thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Sounds like you need to replace the trackpad. Links provided.
http://www.ifixit.com/Mac-Parts/MacBook-...
MacBook Unibody Model A1342 Trackpad Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
That test was done. I have tried deconnecting the trackpad and cable and plugging a new one. No difference. Still the same problem. thank you for your answer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
max 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 709
