이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
@rll58 ... what error are you getting? i serviced a triton unit last month. im sure there are similarities that will help with what your is or is not doing.
found the service manual i had for the triton model. its not the same, however if you go to the troubleshooting section of the manual, youll be able to see what some symptoms and solutions are that you can apply to this model you have.
technical fellow 의
http://www.ersbiomedical.com/assets/imag...
good luck.
technical fellow 의
