주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
하드 드라이브 또는 하드 디스크에 대한 수리 정보입니다. 하드 드라이브는 자기 방식의 데이터 저장 장치입니다. 낮은 비용과 높은 데이터 밀도 덕분에 대부분의 데스크톱, 노트북 및 서버에 사용됩니다.
Fixing a clicking hard drive
Hi, so my rage got the best of me and I hit my computer. When I did hit it, nothing happened, nothing changed, as the OS and the game were installed on an SSD, continued playing as nothing happened. But I needed to restart my computer for something and it took really long time for it to boot up and it made strange noise. I take out the hard drive and everything’s fixed, tried using an enclosure and the result was the same, it made clicking noise and slowed down my computer to a snail and it wasn’t recognized. I know the chance of fixing is small, but I just wanted to know if there’s anything I can try to bring it back or something. I don’t have anything important on it, but additional 1TB hard drive wouldn’t hurt :D
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
If you can copy off anything of importance ASAP!
의
댓글 달기
답변 1개
선택된 해법
That usually means the read heads in the hard drive are stuck from a drop or impact. It would require opening up the drive and using the proper procedure to undo a stuck reading head.
Problem with this is that it would compromise the dust-free enclosure inside and any dust that gets in the hard drive will cause the hard drive to fail quickly.
As it’s reading very slowly it’s most likely the reading heads are damaged and would require a read head swap (getting a identical read head with the right pre-amp is extremely hard to do and requires getting it from a identical donor drive as even the same model can have multiple different pre-amps depending on the manufacturer year and month).
TL:DR - There isn’t any way to repair thats cheaper and quicker than buying another hard drive.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Tomasz Videos 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 19
지난 7일: 103
지난 30일: 427
전체 시간: 9,822
