주요 콘텐츠로 건너뛰기
Repair information for standalone freezers.
Why is my defrost cycle inconsistent?
Fridge-Amana- ARB2517CSR
My defrost cycle is inconsistent. The defrost cycle only works every 4-5 days. The defrost timer seems fine(Check for continuity and the compressor turns on after 30 minutes).
I suspect it could be the thermostat The defrost cycle only works when the freezer/fridge is at its coldest setting when the coils are basically frozen solid(which takes about 3-4 days). Only then, the freezer will defrost itself instead of the usual once every 10 hours.
Anyone had this problem before?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Don’t know the answer but here’s a link to the wiring diagram for the refrigerator which may help. (scroll through the parts diagrams and click on Wiring information).
Does the compressor stop for the required amount of time for the defrost cycle, once every ~10 hours?
If so then perhaps the heater isn’t operating when it should be. If this is the case then it may be the defrost thermostat that is the problem. Here’s how to test the defrost thermostat
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
kkira589 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 111
