주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2005년에 출시된 Blue Microphones의 오리지널 마이크
How to remove the USB B port?
The USB port on the back of the mic seems to be glued with some sort of red cement. To the touch this glue is hard but rubbery.
I’m pretty sure it’s only touching 2 metal parts (the port casing and the thin hexagonal nut) but it might be touching the plastic usb port.
What is recommended to remove this glue? or is there another way to approach this problem and remove the port?
Thanks.
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I would just use a small knife to remove that adhesive that is securing the lock collar. It is likely there to keep the collar from moving, and to keep it into place.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
thank you. it was indeed on top of the collar and not between the threads. :)
의
댓글 달기
답변을 추가하세요
MimaSweets 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 8
지난 30일: 30
전체 시간: 1,259
