주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
573 질문 전체 보기
keyboard typing extra characters
i have an iMac 27" and it is working fine but since a few days the keyboard is acting very weird. While typing the keys its typing extra characters and specifically when i press m its takes the cursor and places before m. When used a regular windows keyboard with wire it works fine but when i type with the magic keyboard its acts weird. Need your help to understand the issues.”
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Hello, you may need to take apart the Apple keyboard and clean it, while making sure no liquid has entered in on anything. I’ve had the same issue with a razor gaming keyboard and it ended up having some Debris in it, that made two keys off set. Once cleaned it’s worked great!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Review this teardown Magic Keyboard Teardown
Sadly, Apple uses rivets to hold the sandwich together so if you had a spill its hard to clean the switches. Popping off the keycaps is all you can do to try to get the junk out which is interfering with the scissor mechanism.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amit Ostwal 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 8
전체 시간: 364
