주요 콘텐츠로 건너뛰기
Wherever you go, bring some big beats with you. The SRS-XB10 is easy to carry and gives your music some extra bass.
9 질문 전체 보기
cracking sound from the speaker
cracking sound is coming in medium and high volume of speaker and when the speaker gives up bass
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Down speaker damage change a parts
=== Update (11/15/2020) ===
Hello bass speaker change
Where am i supposed to get the new bass diaphragm for replacement?
댓글 달기
답변 3개
가장 유용한 답변
@kuleshwar could be a bad speaker coil or ripped speaker cone. You will have to take it apart and check the speaker separately. Of course there is always the chance that this is a bad amplifier (IC or circuit) again you won’t know until you check. Take a look on here for a teardown. After that post some good pictures of your pieces with your QUESTION so we can see what you see and possibly help you further.
기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
this happened to my sister it was just water damage
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Same issue with my srs-xb10.
I’ve opened it just to found its actually the speaker itself having tear within its diaphragm. Sigh
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi i had the same problem that you, my speaker was cracked on my SRS-XB10. I tried fixing it with some Aleene’s Original Tacky Glue but it didn't work because there were many cracks and the speaker was just good for the trash.
I found one seller on Aliexpress that sells a 52mm speaker that looks almost exactly like the original Sony SRS-XB10 speaker and weights the same so probably the same Power. I ordered it, replaced the broken speaker with the new one (perfect fit) and it works like a charm, I didn't notice any major sound difference.
If you are interested the Aliexpress seller is "SOTAMIA Overseas Store" and search for "52mm 10W 4 Ohm Speaker"
https://www.aliexpress.com/item/10050031...
댓글 달기
귀하의 답변을 추가하세요
kuleshwar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 78
전체 시간: 2,938
