주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
어디를 가든 웅장한 비트를 함께 가져가세요. SRS-XB10은 휴대가 간편하며 음악에 깊은 베이스를 더해줍니다.
cracking sound from the speaker
cracking sound is coming in medium and high volume of speaker and when the speaker gives up bass
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Down speaker damage change a parts
=== Update (11/15/2020) ===
Hello bass speaker change
의 공유
Where am i supposed to get the new bass diaphragm for replacement?
의 공유
댓글 달기
답변 3개
가장 유용한 답변
@kuleshwar could be a bad speaker coil or ripped speaker cone. You will have to take it apart and check the speaker separately. Of course there is always the chance that this is a bad amplifier (IC or circuit) again you won’t know until you check. Take a look on here for a teardown. After that post some good pictures of your pieces with your QUESTION so we can see what you see and possibly help you further.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
this happened to my sister it was just water damage
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same issue with my srs-xb10.
I’ve opened it just to found its actually the speaker itself having tear within its diaphragm. Sigh
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hi i had the same problem that you, my speaker was cracked on my SRS-XB10. I tried fixing it with some Aleene’s Original Tacky Glue but it didn't work because there were many cracks and the speaker was just good for the trash.
I found one seller on Aliexpress that sells a 52mm speaker that looks almost exactly like the original Sony SRS-XB10 speaker and weights the same so probably the same Power. I ordered it, replaced the broken speaker with the new one (perfect fit) and it works like a charm, I didn't notice any major sound difference.
If you are interested the Aliexpress seller is "SOTAMIA Overseas Store" and search for "52mm 10W 4 Ohm Speaker"
https://www.aliexpress.com/item/10050031...
의 공유
do you think this one work work
https://www.aliexpress.us/item/325680398...
kinda wanna go over board lol
의 공유
댓글 달기
답변을 추가하세요
kuleshwar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 80
전체 시간: 5,095
