주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2010년 3월 북미에서 출시된 Nintendo DSi의 더 큰 버전입니다. 대부분의 수리는 스크루드라이버와 수리 도구만으로 가능합니다.
Device won't turn on
My daughter came to ne with her DSi XL and said it will not turn on. Indeed when you press the button it flashes then turns off. It will turn on when a game is loading, but turns off immediately after. We have removed the battery, cleaned the contacts and fully charged it. There are no rattles in the case and everythign else seems to be in order. I am guessing it is the power board, but that is just a guess. has anyone else had this experience. Alos it has been dropped, but it had worked for a while after that.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 5개
I bought the dis 3years ago and it worked for couple of months
의
My dsi xl doesn't turns on I'm just waiting for someone to sell me a charger
의
My dsi xl has been broke since 2014 i think
의
Have you charged the dsi?
의
If i try to turn it on, nothing happens, it wont even flash
의
댓글 달기
답변 2개
선택된 해법
Mark, if you are sure that your battery is charging and holding a charge you may want to check the LCD's and the cables, especially to the top screen. Those do have a tendency to break." If the top LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the bottom LCD screen will flash on very briefly when the power button is pressed. If the bottom thin LCD ribbon cable is damaged or not connected properly the blue power light will turn on briefly and the top LCD screen will flash on very briefly when the power button is pressed." Let us know what you find out. Good Luck
이 답변이 도움이 되었나요?
점수 9
댓글 8개:
Thanks! That makes sense. If the screen is at 90 degrees to the console I can push and hold the power button. It powers up and runs, but when I let go it quits. If I push it back one notch, it won't work at all. I have to leave on business, but when I get back I will take it apart and investigate your theory.
의
Sounds good, have a safe trip. Let us know how it turns out.
의
Thanks.... That got it. It was one of the connectors on the ribbon..... Lets see how long it last. Thanks for your help....
의
Great job, good thing you got it working. All the best to you....:-)
의
Hi, I have the exact same problem as above. How do I replace the ribbon?
의
댓글 3개 더보기
댓글 달기
The DSI Fixer Hey if you want your back buttons on your DSI to work all you have to do is blow on them with all your might.Then what you have to do is open it up and see if it works and boom it works again and if it doesn't work sorry. I am telling you this because it worked for me and it turned it on and made it work even better then before.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Wow, thanks! Didn't know that, will try!
의
댓글 달기
답변을 추가하세요
Mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 47
전체 시간: 57,888
