주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2005년에 출시된 얼음 정수기가 없는 상단 냉동고형 LG 냉장고 LRTPC2031에 대한 수리 및 추가 정보를 확인해 보세요. 이 페이지는 LRTPC2031** 형식의 모델 번호에 대한 정보를 다룹니다.
MY LG LRSC2031T Freezer stopped working
MY LG LRSC2031T Freezer stopped working. Then the refrigerator started working. A tech came an looked at it and said the wattave was running too high at 220 Watts. He said it wasn't worth fixing. Charged my wife $80 for that check. He said a person who does "seal system" would be able to fix it. Well when I got home I unplugged it and plugged it back in and it started to work. But then a day later it wan't as cool as the night before. I vacuumed and cleaned the coils. I don't want to spend $3K on another refrigerator If I don't have to. All of the comments above have been helpful.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Drpang1-sounds like the tech didn’t give you much of a diagnosis. If the problem is in the sealed system such as a leak, restriction, compressor, evaporator, condenser problem, the repair must be done by a certified refrigeration technician. Also, the parts are usually covered under the manufacture warranty for maybe 7-10 years. Contact LG.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks LadyTEch! I plugged it in after it died to see what would happen. It stayed cool for a day and then it died again. Could it be the board since it cools but then goes warm. The lights go on and the fan is blowing.
의
Drpang1- im going by what the tech said, it was in the sealed system. You say the fans are running, is the compressor running? Is the compressor cool, warm or hot? Same for condenser coils? When I replace the compressor I usually replace the board also. There are so many revisions made to those boards that it’s just practical to replaced at the same time. Also, it takes about 48 hrs for a warm refrigerator to reach its set temperature. If your coils were dirty, chances are that is what caused your problem to begin with. Dirty coils cause the condenser and compressor to run hotter than they should. This heat causes issues with the refrigerant/gas. The heat will cause a lot of issues such as a leak in the copper tubing, restrictions due to moisture entering the system, and more. Keeping the coils clean is very important. It’s just like changing the oil in your car. It’s vital. Your owner manual explains how often the coils should be clean and if you have inside pets, to clean more often.
의
댓글 달기
답변을 추가하세요
drpang1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 13
전체 시간: 224
