주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ninja Mega Kitchen System BL770은 SharkNinja에서 제조한 종합 주방 가전입니다.
Replacing broken plastic gears
Our Ninja BL700 stopped spinning. I disassebled the unit and the plastic 3 gear unit at the top had shredded teeth not allowing the unit to spin. Ninja does not offer a replacement part but saud I can purchase a replacement base. Does anyone know where I can purchase the part. An internet search has not been fruitful. Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
The person that answered your question isn't DIY savvy. You tore your unit down to find the 3 gear cluster inside the white casing. Apparently this is the main failure in the Ninja brand. I'm also trying to find a replacement, but you're the closest I've come to finding anything online.
의
댓글 달기
답변 1개
If you are talking about the gear-looking part on the drive shaft that meets with the bottom of the blade assembly, it is called a coupler or coupling. I haven't found one for Ninja, but there are a lot for kitchen aid and waring around. I would wonder if one of these is 'compatible'.
Example: https://www.ereplacementparts.com/coupli...
Update (10/17/2020)
Similar question: The flexable rubber coupler has broken..
In that, this guide is referenced which includes a rebuild of the planetary gear assembly. I see now this is what you really needed
https://sites.google.com/site/dgeake51/h...
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
No. It is the gear unit that turns the coupler.
의
Broken 3 gear unit that turns the coupler.
의
댓글 달기
답변을 추가하세요
Tim Strickland 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 48
전체 시간: 2,555
