주요 콘텐츠로 건너뛰기
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
20 질문 전체 보기
The screen only turns black after having replaced it
When it worked, the screen had vertical lines going through it.
It turns on and sound comes through so it isn’t bricked.
I tried re-inserting the screen several times.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I have the same issue. Had vertical lines and a crack on the edge. Bought a replacement LCD screen, changed it out with no problems, put battery in and powered on to test it. The screen is lit and you can see light around the edges of the screen. You can tell when you adjust the screen brightness but it's just a blank screen. There is sound and you can hear it clicking when you scroll but that's all.
댓글 달기
답변 2개
선택된 해법
Hi,
Just verifying that you had the battery disconnected when replacing the LCD screen and also when disconnecting and reconnecting the replacement LCD screen multiple times?
If you have a DMM (digital multimeter) use its Ohmmeter function to check that the display’s backlight fuse is still OK and not open circuit (blown). It should measure 0.00 (Zero) Ohms when the meter leads are connected, one to each end of the fuse. Do this with the battery disconnected from the device.
Here’s an image that shows the audio fuse (red arrow - F2001 - 1.0 Amp) and the backlight fuse (green arrow - F4101 - 0.5 Amp) The image was used before for another answer so the red box was only to show the value of the audio fuse.
(click on image to enlarge for better viewing)
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
There was no battery at all when I bought it so it has only been tested while directly connected to the AC adapter.
@ loke olson
Still check the fuse as it may not be obvious that it has blown.
At least you have eliminated it as a possible reason why the screen doesn't work.
Also you don't know what was done to the device before you got it.
댓글 달기
@ loke olson did you replace this with an LCD? There is an OLED conversion out there you can replace it with but it requires soldering a jumper to get it to work and would give you the issue you have if you didn't mod the board.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It was an LCD.
댓글 달기
답변을 추가하세요
loke olson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 22
전체 시간: 822
