주요 콘텐츠로 건너뛰기
The Asus Q551L is a 2 in 1 device released in 2014 by Asus. The screen is 15.6" and the device comes with a 2 GHz Intel Core i7 processor.
Why can’t I boot into windows with a new ssd
Hello, I’m trying to upgrade my grandmas HDD with an SSD and whenever I try to boot, it takes me straight to the bios/uefi . Am I doing something wrong? I have windows already pre installed and if you were wondering what the ssd is, it’s an 860 Evo 1TB. Please get back to me as soon as possible as I’d like to get it running it’s best.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
@aactech as a Windows guru, what do you suggest?
Hi @dabadabadokio ,
When in BIOS does it show that the SSD has been detected?
If not check the SSD connection to the motherboard.
Did you make the SSD bootable when you installed the OS on it?
I am not sure how to get to the boot options since I’m more familiar with desktop bios rather than laptop bios
@dabadabadokio
Hi Noah,
You stated ". . . it takes me straight to the bios/uefi " so you are already there.
댓글 달기
답변 2개
선택된 해법
Hi Noah,
You stated ". . . it takes me straight to the bios/uefi " so you are already there. If still puzzled download the manual:
https://www.asus.com/supportonly/Q551LN/...
Another thought. How did you clone your grandma's HDD to the SSD? This is very important. The easiest with the Samsung Evo is to just use their utility:
https://www.samsung.com/semiconductor/mi...
Look for "Consumers' Data Migration Software v4.0
You might also download the instructions for it.
You also say you have Windows preinstalled. . . where? On her old drive and it boots fine?
If that is the case then Samsung’s “Data Migration Software v4.0” will solve all your problem.
Let us know how it goes.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Does the SSD have an OS installed? If not, that’s typical with Asus laptops if it can’t find an operating system - although some do boot to a no bootable devices screen.
Put a USB stick in the machine with the correct OS you want to install, and it should boot into that. If it doesn't, the page where you save or discard changes usually has a one-time boot menu as well as a dedicated function key.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Yes it has a boot is installed already on the ssd. It’s windows 10 home
댓글 달기
답변을 추가하세요
Noah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 413
