주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Panasonic Lumix DMC-FZ1000은 2014년 7월 27일 Panasonic에서 출시한 회전형 화면을 탑재한 디지털 일안 카메라입니다.
Grinding Noise - Non-operable
My FZ1000 makes a grinding noise when I turn it on. It doesn’t do anything besides that annoying noise, as if it’s locked up.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
This sounds like the problem I had which I was able to repair.
In my case the problem was that the screws securing the zoom motor loosened, allowing the worm gear to skip while turning.
Solution was to tighten those 2 screws INSIDE the zoom motor assembly.
Step 22 of the disassembly guide shows removal of the zoom motor assembly. If you can feel play between the motor and the zoom motor assembly case, it's the same problem.
The zoom motor assembly case must be opened to reach these two screws.
이미지
Search my username on DPReview, I have a public gallery with photos of the repair.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yolanda 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 35
전체 시간: 337
