주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi 9는 2019년 2월에 출시된 Xiaomi의 중급 스마트폰입니다. 6.39인치 Super AMOLED 디스플레이, 48MP 메인 카메라와 16MP 초광각 및 12MP 망원 렌즈, 디스플레이 지문인식 센서, 고속 무선 충전을 지원하는 3300mAh 배터리를 탑재했습니다.
Fingerprint not working after screen replacement
Hey guys
have replaced the screen (whole unit with frame) on this Xiaomi Mi 9
afterwards the fingerprint Sensor did not work properly. It hardly Scans the initial fingerprint but won’t unlock the phone with it or allow any other fingerprint functions.
I have already removed it and replaced it again. as it is embedded into the Display Unit I Wonder if this is a problem concerning the display unit or the fingerprint scanner itself.
if it is the fingerprint scanner, would it even be possible to replace it or is it like on iPhones „married“ to the motherboard?
would appreciate your support guys
keep fixing
peace
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
I feel like it has to do with the screen. Where did you get the part?
의
Did you fix it? Have the same issue after my screen replacement
의
I have the same problem here.
의
댓글 달기
답변 5개
Exactly the same here.
Bought Frame + Display on ebay (Germany). Everything works perfect except the fingerprint sensor.
"Learning" a finger is hard. Only every 10th scan is recognized. Other 9 fail with messages like "too fast" or "dirty sensor".
Unlock has two different behaviors:
1) On ambient display: It never works (which previously did). The sensor "scans" for around 300 milliseconds and fails. With the old display it took the same amount of time but it worked.
2) After pressing power button: It takes about 1 second (which is a really long time) for the scan to be completed but works most times (9 out of 10). Previously it worked much faster.
/edit
Just found out that it does NOT work properly in the “power on button” state. After 1 second the device gets unlocked, BUT it also gets unlocked with unknown fingers! Maybe it focusses something in the display?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I highly doubt it's the phone's fault, but rather a bad quality part. This is why you have errors
의
댓글 달기
Apparently the latest software blocks the figure print replacement from working.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I’d first check if the fingerprint sensor or the scan hole are dirty, and clean them. Afterwards, try erasing all the fingerprints and re-adding them. It’s possible that a software update started to pair displays to the motherboard, so one way of fixing this would be using a custom ROM. Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Late update: just had a client with a similar problem.
Turns out the fingerprint sensor is really sensitive to the positioning, so if you bent one of the plastic positioning pins even slightly, it will register the first few scans, but fail after. I'd suggest getting a new one if that's an option, as well as cleaning the glue residue, then adhering the new one in place with the right thickness of new adhesive tape (I think one or two layers of a B-7010 type double-sided should do, does require some trying however).
의
댓글 달기
https://www.youtube.com/watch?v=9jKmbfP2...
This is work propertly :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi all,
I have recently replaced the display of the Mi 9 (from Aliexpress).
After installation the fingerprint worked and when I tried again after the factory reset the input was failing and after multiple tries, I was able to add the fingerprint.
One way I overcame the fingerprint unlock problem is by adding the same finger multiple times.
이미지
I tried to do the calibration through CIT but I'm getting Auto_Exposure test fail.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jimmy industries 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 41
전체 시간: 9,023
