주요 콘텐츠로 건너뛰기
The Infinity v2 10.1 inch tablet, running Android OS , was introduced in 2014.
3 질문 전체 보기
How to I do a factory reset, I tried the power and the +volume
I tried to reset n unable to change the password how do I do a factory reset
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
To reset the device, there is a reset button located on the bottom of the device located next to the mic. To activate the button you must stick a pin into the hole where the reset button is located.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi,
Did you do it this way?
Press and hold Volume + button and the Power button at the same time.
The tablet’s screen should turn on.
When it does release the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Nothing happened still won't turn on
@jamesdewey35486
Does the tablet show that it is charging when the charger is connected?
댓글 달기
귀하의 답변을 추가하세요
anu harigyan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 33
30일 전: 126
전체 시간: 1,056
