주요 콘텐츠로 건너뛰기
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 질문 전체 보기
Ds lite power switch broken
I have a ds lite that i recently opened up, and i realized that the power switch was broken, it powers on but the switch is broken and i need a flat tip screwdriver to power it on and i dont want to desolder it to risk damage to the board
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@hithere145 depends on how it is broken. If it is just the slider, you can replace that. Nintendo DS Lite Power Switch Replacement If it is the actual switch, it needs to be replaced and will require soldering. If you don’t think that you cannot manage this task, see if somebody can maybe solder it for you. Remove the board, desolder the old switch and replace it Nintendo DS Lite Motherboard Replacement
Nintendo DS Lite Power Switch 이미지
안내서
난이도:
쉬움
10 minutes
Nintendo DS Lite Motherboard 이미지
안내서
난이도:
운영
25 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
It was the slider on the switch itself, not the plastic piece
@hithere145 in that case the only way to really fix it is by soldering a new switch in place.
댓글 달기
귀하의 답변을 추가하세요
Gianpiero Paredes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 46
전체 시간: 1,901
