주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AirPods Max 무선 노이즈 캔슬링 헤드폰에 대한 수리 및 분해 정보입니다.
Is AirPods Max battery user replaceable?
Can a common user replace Airpods Max battery ?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 달기
답변 4개
선택된 해법
Officially, its not user serviceable, at least this is what Apple will tell you.
But as the teardown shows, once you get below the only point where they used adhesive, you can quite easily replace them. Or could - since you would have to find a replacement part first. But the batteries are not glued down and they do have a real connector! These AirPods Max did get 6 out of 10 Points for being somewhat repair friendly - contrary the the other members of the AirPods family, who earned a whopping… 0 points !
이 답변이 도움이 되었나요?
점수 7
댓글 달기
Unknown at the moment, check back to the teardown for an answer later.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Ooh, would be nice if a bigger capacity battery was made for the AirPods Max. I think I’m only getting ~6 hours with noise canceling on and the volume at “4 from the highest”. And my commute is ~45 mins each way.
의 공유
댓글 달기
Yes it is! Just need to get batteries that work.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
They’ve just launched - wait for the teardown.
Although it’s most likely going to be a no.
이 답변이 도움이 되었나요?
점수 -1
댓글 1개:
seeing has how the cups can be moved, and only adhesive holds the plastic covers down, I don’t think it would be *that* difficult compared to some other Apple products.
의 공유
댓글 달기
답변을 추가하세요
Babu s 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 17
지난 30일: 62
전체 시간: 14,149
