주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volkswagen은 골프 Mk6를 기존 골프 Mk5의 PQ35 플랫폼을 기반으로 제작했습니다. 이 차량은 2008년 파리 모터쇼에서 처음 공개되었습니다.
Hatch Lock triple square bolts
To replace failed hatch lock mechanism, need to remove two “Triple Square” (12-point) bolts that attach lock to hatch panel. Videos say use an MM8 bit but it’s too large, MM6 bit is too small. Cannot find an MM7 in any set or anywhere on internet - if it exists??
Since hatch lock replacement is a common problem, has anyone dealt with this issue?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
I struggled with a couple of bolts like them on a audi before, I got one of those cheap multi size socket ends for the ratchet that have them small hex shapes inside on springs, got the bolts off and then just replaced them with standard bolts after to avoid the problem again. The size as far I was aware for these was MM8 though.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Correct, I had the same problem. Bought an mm8 bit due to other people saying it was mm8 and it was too large. My bolts were mm7, plenty can be found on Amazon.
However my bolts were on so ridiculously tight that I ended up stripping one of the bolts.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Golf GTI mk6. M8 triple square bit was too big. Awaiting an M7 from eBay uk as I could not find one in Australia. May have stripped both bolts trying to remove them. Fingers crossed that an M7 will do the trick. They are in very tight indeed.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Richard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 46
전체 시간: 3,860
