주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
27" 화면 2560 x 1440 픽셀 해상도 Thunderbolt 및 MagSafe 케이블 부착물
Chemical smell... power supply?
Hello, I started noticing a strong chemical smell coming from the bottom left air-vents of the Thunderbolt Display, but no other signs. The brightness is fine, it powers the MacBook, and no strange behavior. I ordered a PSU replacement, did I make the right choice? Should I also replace the FAN? (but I’m finding only used fans…)
Update (02/18/2021)
@danj Thanks Dan, mine is different. Look at the photo, I marked what seems to originate the bad smell. Is still the component you mentioned before?
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 22개:
Without opening it up to inspect things it could be anything!
의
Hello Dan thanks, yes it could off course... but I didn't want to open it without first having something to swap, as I have fear for that delicate wires that need to be disconnected to separate the two monitor parts. I wanted to know if, based on experience, this smell could indicate a faulty PSU, as the fan itself shouldn't make burning smell (am I right?), and it pushes air through the PSU pub and then it gets out on the left air vent at the bottom
의
I've replaced more logic boards than PS on these monitors. A fan would not be the first thing I would suspect.
의
Thanks, so I need to open it and check every power rail I suppose? At this time not other sign of malfunctioning (unfortunately). I could keep in using it, but the only thing is I have fear the smell could be toxic.. what did you find on defective logic boards?
의
Burnt caps mostly
의
댓글 17개 더보기
댓글 달기
답변 1개
Here’s a marked up image of some of the of the major parts
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vanx 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 1,462
