주요 콘텐츠로 건너뛰기
마더보드 및 CPU 수리 안내서 및 지원.
165 질문 전체 보기
Headphone jack replacement possible?
Hey guys, I have a motherboard that gas been running for 2+ years and my headphone jack snapped off and got lodged inside the rear audio output of my motherboard. My stupid self tried to drill out the jack but instead broke the port itself. Is there any way I can replace it? I have the necessary tools to do so. The jack is made by lotus if you were wondering. Thank you!
Edit: the motherboard is the Gigabyte GA-Z68x-UD3H
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@zantheproplayz post some picture of the broken part as well as the underside of your board with your QUESTION. It is most likely possible but you may have difficulties finding a proper replacement. You could try and match a replacement by measuring your old one and then checking with Mouser, Digikey, Jameco etc. for a replacement. Let’s see how bad this looks. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
You can’t really see the damage in picture but it a mix of plastic shavings and metal
I am actually more interested in seeing the connectors location, shape etc as well as the underside to see if it is a through-the -hole connector etc.
Its a tht connection and the whole entire thing is a rectangle like shape
@zantheproplayz
Is there any information printed on the component itself that may help to identify it.
I know that it is a 6 x RCA type but finding a complete unit is proving difficult.
You may have to connect via the front panel audio headers - see p.29 Item #12 if you can't get the required part
댓글 달기
귀하의 답변을 추가하세요
Zander Castillon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 56
