주요 콘텐츠로 건너뛰기
스크린 크기 5.3” 스크린 해상도 1280x720 Pixels 배터리 용량 2,700 mAh 카메라 해상도13MP 프로세서 Qualcomm Snapdragon™ MSM8917 1.4GHz Quad-Core 메모리 2GB RAM 저장 용량 32GB ROM (최대 사용 가능 23.21GB) 통신사 T-Mobile 또는 MetroPCS 다른 기능 Android 7 (Nougat) 운영 체제, 5MP 전면 카메라와 제스처 샷 & 셀피 빛, 4G LTE 연결성, 모바일 핫스팟, Rear Key/리어 키 지문 센서. 모델 TP260 및 MP260
20 질문 전체 보기
Why won't my phone turn on after charging?
Ok, can someone help me with this...I have an LG k20 Plus phone and just three days ago, it went dead on me (as in the battery ran out.) So I went to charge it. After around an hour of letting it charge, I decided to come back and check on it. I tried turning it on, but it won’t work. So I decided to let the phone charge overnight because I thought it just wasn't charged enough or something. The next day I tried to turn it on again but it didn't work. I also tried pushing both the volume down button and the Power key in order to reboot it, but that also didn't work. I tried everything from taking the battery out and looking at youtube videos to putting it in the freezer (again, from a youtube video). Does anyone have any suggestions for this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi BelmontRose 1622 , I had read your Question about your phone current situation, i am recommending you to checking the battery first, if it corrided or any problem happened clean the pin, if it not helping you check he battery voltage and connection, is it indicating any light? while on charging, , also you can check the phone by connecting to PC, if it shows any detection of phone?, if all are not you should checking phone charging I C, i hope you got your solution
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello, my apologies for taking so long to respond. I ordered a new battery for the phone but it didn't work. The phone also doesn't indicate any light while on charging and the PC didn't recognize nor detect the device when I connected it with the USB.
댓글 달기
답변을 추가하세요
BelmontRose1622 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 987
